Creaver
BBS 17x8
They are the ultimate wheel for a e24 6er though.
I'd do a 5 stud conversion just for these, would look the bees knees on an e30.
Maybe if I got a bigger student loan :lol:
And of course, paint the centers gold. ;)
Nice on an E28 M535 too.........mmmmmmmmmm :wub:
Guest SamSpargo
Already have a 5 lug E30 with gold centre BBS 17's :D
Yeh, I saw these... look sooo sooooooo sexy!
Anyone know if these will fit an E36??
You might have a fight on your hands! Soo tempted. :P Edited by Nick021
Yup they will... but I see from your for sale thread you've already figured that out! :D
Do it... those style 5's will look sooooo hot!
lol, well you do have the upper hand mate. You live in Auckland... If these were in Christchurch and I could see them up front AND they fit I really doubt I could hold back.
I am still unsure... are you 100% certain?
Edited by crazyarab
they won't fit e36's without spacers to clear the brakes and guard rolling
WTF :wacko:
Where do you guys come up with your information?
They have come off a 6 series = 5 series offset.
3 series and 5 series run different offsets = NOT COMPATIBLE!!
WTF :wacko:
Is there absolutely no way you can make them fit?
Guess I'd better get these graeme :D
Like an addict to the bottle....
Did you ask about the offset on TM? I noticed he has put 7jj which would indicate the wheels are 7" and NOT 8" wide.
Short answer = no :P
Long answer
The wheels from a 5/6/7 series stick out too far on a 3 series.
Just to clear things up the lower the offset the further out the wheel will sit.
5/6/7's generally run around 20 et factory.
3 series generally run around 40 et factory.
Also the wider the wheel the further out it will sit as well.
These wheels may just fit at the back but will defitiely stick out at the front = FAIL WOF!!
If you run spacers as suggested earlier the wheel will stick out even further!
I have some 16x7.5's here at 20 offset which I will stick on an E36 and take a photo for you and post up later to show how far out they sit.
cheers
Johno
17x9.5 BBS RS on E30 M3
16x8 BBS RS 5x120 at ET20 offset - were on E30 M3 also...
I think the e30 M3 runs similar offsets etc to a 5 series. E31/32/34 etc wheels fit on an e30 m3 without changes i believe...a direct fit.
*edit* might need spacers?
Edited by Creaver
correct :D
E30 M3 = 5 series offset
E36 M3 = 3 series offset
E46 M3 = 3 series offset front, 5 series offset rear
other than that 3 and 5 series are not interchangeable
Guest SamSpargo
Guess those photos are photochopped then...
Or could it be with enough time and effort, you can make anything fit?
With enough money.
