pureboiracer 0 Report post Posted September 14, 2008 got my turbo manifold sitting on the e30 now. saving for the turbo. it will be a t3. but the small issue is where will i put the downpipe. included sum pictures. have about 2" or so either side of the steering collum. anyone got any ideas? Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted September 14, 2008 pic doesn't work for me, but you can squeeze a 3" pipe between the motor and the steering column Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted September 14, 2008 not with this manifold you cant. there is no more than 6cm either side of the steering collum Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted September 14, 2008 Pic doesn't work for me either. Quote Share this post Link to post Share on other sites
320guy 0 Report post Posted October 22, 2008 You can also fit a 3" pipe between the steering column and the body. Stop making excuses! Quote Share this post Link to post Share on other sites
pjay 8 Report post Posted October 22, 2008 Sorry, an error occurred. If you are unsure on how to use a feature, or don't know why you got this error message, try looking through the help files for more information. The error returned was: Sorry, but you do not have permission to use this feature. If you are not logged in, you may do so using the form below if available. Quote Share this post Link to post Share on other sites
m&ttaur 0 Report post Posted June 4, 2010 got my turbo manifold sitting on the e30 now. saving for the turbo. it will be a t3. but the small issue is where will i put the downpipe. included sum pictures. have about 2" or so either side of the steering collum. anyone got any ideas?Hi did you get your e30 finished? I have one of those manifolds and had to modify the 2 rear port pipes? but now i have found the chinese guy who welded it welded the flange on upside down!!!! was yours right and did you get it from driven performance? Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted June 4, 2010 the pic is HUGE and wont auto resize down. Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted June 4, 2010 Hi did you get your e30 finished? I have one of those manifolds and had to modify the 2 rear port pipes? but now i have found the chinese guy who welded it welded the flange on upside down!!!! was yours right and did you get it from driven performance? I got mine from there and it fit and worked fine, managed to get a 2.5" pipe between the gap above too using the same manifold Quote Share this post Link to post Share on other sites
