Cale
E30 alarm
The alarm in my e30 has been playing up lately. Everytime I set the alarm and leave the car, about 60sec later the it goes off, everytime, no reason. I cannot figure out why. Is it a broken sensor somewhere or something?
I believe it is the ancient original alarm (has the square black speaker, left front engine bay?)
Thanks.
Thanks.
Wont be original - they weren't fitted
Maybe a door,boot or bonnet switch faulty/bent
Is the interior light tuning on/off with all doors correctly?
Cheers, I will check all that out.
Yes lights work with doors.
Thanks.
Could be a number of things. If you’re in Takanini call in and see Carl at Live wire Auto & Marine, he is a top bloke and a friend of mine and will most likely have a look straight away. Say your from Bimmersport and you know Graham ;)
It’s the next drive way after Papakura Toyota, across from the whore house ^_^
Guest SamSpargo
"While you wait"
Central locking module failing can trigger them too.
Auto sparky job or easy to do yourself?
