User Name 19 Report post Posted September 15, 2008 Hi Guys as you know ive being doing on engine conversion from a e32 M30B35 into my e28, i have manged to wire the ecu into the e28 loom and now i have a few problems 1. no Fuel is getting to the fuel rail even tho there is fuel going to the pressure regulator. 2. the fuel pump relay has stoped working, worked when first wired up, plugs getting power but switch not going have tried another relay so geuss ECU. Have tried other pressure regulator no fuel came out at all, but had to jump jumper 30 -87 on relay to bypass and get fuel to pum, turned over engine nothing fuel injectors fine, only thing i guess is ecu any ideas of ways of testing, could no vaccum cause this Cheers any question as spent all w.e checking wiring etc no luck Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted September 15, 2008 (edited) 1. no Fuel is getting to the fuel rail even tho there is fuel going to the pressure regulator. I am not sure this is actually possible. I suggest you put a fuel pressure gauge on it and find out if you have pressure (rather than just flow). Edited September 15, 2008 by CamB Quote Share this post Link to post Share on other sites
User Name 19 Report post Posted September 16, 2008 Yea im going to see if i can get one this week, still doesnt explain why the fuel pump relay stoped working on me all i can think is a ecu fault code stoping it, yea but if it had pressure on the old engine it shouldnt have being stuffed Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 16, 2008 (1) Youve got the hoses around the wrong way...pressure goes into the rail and the regulator maintains constant pressure in the rail and returns excess fuel to the tank. (2) Best get a sparky to check that out. You may not be getting a signal for the relay. Is it 4/5 pin or tachometric ?? Quote Share this post Link to post Share on other sites
User Name 19 Report post Posted September 16, 2008 Thanks Glen thatl be the fuel one solved, cause i had changed them arround cause it hadnt started when i turned it over ill swap them back round, yea looked at it and it all seems fine except for it not working, and it is a 5 pin relay and the rest of the things are working on it CHeers kym Also anyone got a trick for getting rustted rotors off once the screw starts stiping or just drill it out and put a new screw in it Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 16, 2008 (edited) You could temporarily keep pin 30 & 87 bridged to get everything else sorted and deal with that problem later. If you cant figure out the wiring fault yourself. Just remember to unplug it when you stop the engine and never drive on the roads like that. Edited September 16, 2008 by *Glenn* Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted September 16, 2008 You could temporarily keep pin 30 & 87 bridged to get everything else sorted and deal with that problem later. If you cant figure out the wiring fault yourself. Just remember to unplug it when you stop the engine and never drive on the roads like that.Could you bypass the relay by placing a switch in the cabin for the 30/87 bridge? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 16, 2008 Could you bypass the relay by placing a switch in the cabin for the 30/87 bridge? You could...but not advisable. If you have an accident the fuel pump doesnt stop which could be disasterous Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted September 16, 2008 You could...but not advisable. If you have an accident the fuel pump doesnt stop which could be disasterousDedicated race car, wired thru the kill switch? Quote Share this post Link to post Share on other sites
