far4ngn
OBC Bulb Part number
In the Facelift E30 with an OBC, the display can be fixed by buying a light bar...small white piece of plastic with two bulbs. I'm wondering if anyone has the part number available, so I can order from BMW.
Cheers
Paul
Guest SamSpargo
Replace them with LED's for double the brightness. OBC is way too hard to read normally
I wouldn't recommend going Will's way. I did it like this to replace the bulb in my clock, and had no end to trouble trying to put it back together. Apparantly there is a way to remove the OBC by removing the glovebox, and leaving that front control panel intact.
Mark, yup part 4 is what I need...I replaced part three thinking that was the bulb...duh!
Martyn, thanks for the info...I'll be taking the centre console etc out again and may have a go using 12v bulbs or LEDs. See if I can get them from BMW first.
