Edurty 0 Report post Posted September 25, 2008 hi there ppl i was wondering if there is anybody out there that can help me here i have a person that has a second hand fuel pump, but the thing is that the last series of numbers doesn't match up to the series of number that are on my fuel pump, would this cause a problem if i were to get a mismatched series of number on the second hand fuel pump and install it to my car????? please help Quote Share this post Link to post Share on other sites
User Name 19 Report post Posted September 25, 2008 I reakon have a look on the net and check real oem i replaced my fuel pump with one out of another bmw but being as it was bosh and had same pressure etc and worked fine what sort of car do you have? just reakon if all else fails im sure someone on here might be able to swap you or give you a cheap one Quote Share this post Link to post Share on other sites
Edurty 0 Report post Posted September 25, 2008 I reakon have a look on the net and check real oem i replaced my fuel pump with one out of another bmw but being as it was bosh and had same pressure etc and worked fine what sort of car do you have? just reakon if all else fails im sure someone on here might be able to swap you or give you a cheap one i i have a 1989 320I facelift model sedan Quote Share this post Link to post Share on other sites
