sin-drome 0 Report post Posted September 26, 2008 hi there im currently installing an amp and subs into the boot of my e30, i know your meant to wire the negative to the chassis but my negative cable isnt long enough, do you know where else i can connect it to ? thanks Quote Share this post Link to post Share on other sites
Jeddy 0 Report post Posted September 26, 2008 Seat belt mounts Quote Share this post Link to post Share on other sites
sin-drome 0 Report post Posted September 26, 2008 cheers thanks mate i'l give it a go now thanks alot Quote Share this post Link to post Share on other sites
Jeddy 0 Report post Posted September 26, 2008 cheers thanks mate i'l give it a go now thanks alotIf your amps on the floor in the boot, run it through the hole in the ski hole thing then remove the back seat and run it to the mount. Maybe give the area a little sanding to make the connection better. Quote Share this post Link to post Share on other sites
bravo 34 Report post Posted September 28, 2008 There's as many as three factory earth points in an e30 boot: One for electric aerial, one by the rear firewall, and if the battery is in the boot (not in this case I'd guess) one on the RHS by the wheel well. Quote Share this post Link to post Share on other sites
