1rotty 40 Report post Posted October 19, 2008 Hey guys,The right rear window on my 540 wont lower. I've had the door card off-motor works fine in both directions,the pull cable is intact & seems to be doing what it should. Is there a pulley or similar on the window arm(up where you cant see) that could be disconnected or stuffed. Any help would be much appreciated.I hate stuff that doesnt work.At least its stuck up! Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted October 19, 2008 In the E34 Mark you fix little niggles like this by holding the window button down and giving the inside of the door a bang with your fist Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted October 19, 2008 have parts if needed. 021433600 Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted October 20, 2008 Hey guys,The right rear window on my 540 wont lower. I've had the door card off-motor works fine in both directions,the pull cable is intact & seems to be doing what it should. Is there a pulley or similar on the window arm(up where you cant see) that could be disconnected or stuffed. Any help would be much appreciated.I hate stuff that doesnt work.At least its stuck up! The regulator (pulley) inside the door will be damaged. Replace it. With a new one they deteriorate due to age - plastic gets brittle - so don't fit a 2nd hand "old" one as you don't know how long it will last. Fit a new one. Quote Share this post Link to post Share on other sites
1rotty 40 Report post Posted October 21, 2008 In the E34 Mark you fix little niggles like this by holding the window button down and giving the inside of the door a bang with your fist Tried that-be back from the panelbeaters on Mon! Quote Share this post Link to post Share on other sites
1rotty 40 Report post Posted October 21, 2008 The regulator (pulley) inside the door will be damaged. Replace it. With a new one they deteriorate due to age - plastic gets brittle - so don't fit a 2nd hand "old" one as you don't know how long it will last. Fit a new one. Thanks Jochen & Brent-is this pulley at the top of the winder mech ie attached to the window glass arm?(where you cant see) Quote Share this post Link to post Share on other sites
1rotty 40 Report post Posted October 23, 2008 Thanks Jochen & Brent-is this pulley at the top of the winder mech ie attached to the window glass arm?(where you cant see)BUMP-anyone? Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted October 23, 2008 BUMP-anyone?sorry havn't looked at one closly .but i think you will need to remove the mech to view it properly . i do have a good mech if needed . 021433600 Quote Share this post Link to post Share on other sites
1rotty 40 Report post Posted October 23, 2008 sorry havn't looked at one closly . but i think you will need to remove the mech to view it properly . i do have a good mech if needed . 021433600 Thanks mate-I'll get in touch once I've got it out. Quote Share this post Link to post Share on other sites
