tiripiri 0 Report post Posted March 29, 2009 (edited) 2 days ago i recived my MegaSquirt ECU. It is MS2 PCB V3 with belectronic boost control. I got it unassembled so i can learn about it bit more. Here is my delphi 37lb/hr injectors. I just heve to gett conections for them. I just wondering I heard that some GM cars 2001+ use Delphi injectors. May some body know wish cars,cause i was in scrap yard yesterday and didn't found smiler ones. Edited March 29, 2009 by ingus Quote Share this post Link to post Share on other sites
tiripiri 0 Report post Posted March 29, 2009 I assembled stimulator and it worked strat away! After that i started put together ECU and offcourse problems started First i had problems to instal and make working Serial communication (usb converter). But it works now. After that i soldered Input section and when i start to test it i cant get RPM working . MAT CLT and TPS from stimulator responds well on Megatune but no RPM! I soldered PWM cicuit cause i will use original PWM idle valve. I checked everything 2 times. Jumpered D2 diode but nothing RPM dosnt work . Maybe some one had this problem before? Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted March 29, 2009 wow that turbo looks impressive and those injectors are massive aswell going to be so awesome when finished Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted March 29, 2009 Great progress - I am a bit concerned that I didn't go the extra mile and get the head welded on my M10, but they have a less bad reputation and I have o-rings on the block. I suggest you ask the question about megasquirt at one of the forums that specialise in it. You should get a quick and good answer there. Quote Share this post Link to post Share on other sites
tiripiri 0 Report post Posted May 9, 2009 There short video of my project car: I still have some prolems with idle and some oil leeks. But soon i think it will be ready Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted May 9, 2009 Looking good man, Very clean! Quote Share this post Link to post Share on other sites
Apex Effects 3 Report post Posted May 11, 2009 whats the reason for the welding on the head? are you not kinda blocking off the water galleries? are m30 got a similar fault? Quote Share this post Link to post Share on other sites
Boost Junky 1 Report post Posted May 11, 2009 Looking awesome There short video of my project car: I still have some prolems with idle and some oil leeks. But soon i think it will be ready Oil leaks are a pain aye! I have a descent one coming out the exhaust side of my cover which is apparantly a common fault running the cometic MLS headgaskets... Quote Share this post Link to post Share on other sites
Apex 693 Report post Posted May 11, 2009 Nice work Ingus, fantastic looking/sounding car. Quote Share this post Link to post Share on other sites
