325isimon 0 Report post Posted October 29, 2008 I have a custom clutch pedal set up on my 95 325i. I am going to remove and install a factory E36 pedal box. Do I need a smaller brake booster to allow for clearance or will the stock booster be ok? Any advice would be much appreciated Quote Share this post Link to post Share on other sites
Guest SamSpargo Report post Posted October 29, 2008 Only you can really measure this - It's a swap by swap basis. Borrow one from one of the guys that breaks cars here and find out the answer! Quote Share this post Link to post Share on other sites
westy 614 Report post Posted October 29, 2008 There's no pedal box in an e36. I'm not entirely sure I follow what you're asking, but I know that the brake master cylinder is the same for autos and manuals. The clutch master cylinder is mounted direct to the pedal under the dash and shares the reservoir with the brake. The clutch pedal hangs off the other side of the pedal bracket from the brake pedal. Check out realoem.com for exploded pictures. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 29, 2008 Its not a box as such. Its an aluminium pedal support bracket and to fit it to an E30 would take some serious modification and fabrication work. It would also need certifying. Why do you want to do this ?? Quote Share this post Link to post Share on other sites
westy 614 Report post Posted October 29, 2008 Its a 95 325 ya noob! Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 29, 2008 (edited) Its a 95 325 ya noob! Oooops Too many E30 problems ATM Maybe the custom clutch set up was installed for the Honda conversion Edited October 29, 2008 by *Glenn* Quote Share this post Link to post Share on other sites
Guest SamSpargo Report post Posted October 30, 2008 I think I get what you're saying: car was originally auto and they didn't change the "pedal box" So you're asking if you can fit a regular clutch pedal and not have to dick around with the brake master and booster? Quote Share this post Link to post Share on other sites
