tight_pants 0 Report post Posted December 2, 2008 i just bought this 740iL and its done 250 000km. still runs mint but gets hot reall fast and leaks water as soon as i put it in as if there is a bottom hose missing. also when i put water in the rad when the car is on the water bubbles. now there is no oil in the radiator and no water on the dip stick. what disease has my car got?? Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted December 2, 2008 Gingervitus? love ashkan Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted December 2, 2008 dehydration...hahaha but seriously... water pump failed??? Quote Share this post Link to post Share on other sites
QuickSilver 0 Report post Posted December 2, 2008 (edited) Water bubbling in the coolant could mean that there is pressure leaking into the cooling system, the only way that can happen is by a cracked headgasket, cracked head, or cracked block. It would be leaking out of the combustion chamber which is why you see no oil mixing with coolant. Edited December 2, 2008 by QuickSilver Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 2, 2008 Guys...dont assume (bad word) it would need to be checked properly by a professional Quote Share this post Link to post Share on other sites
BreakMyWindow 1963 Report post Posted December 7, 2008 what disease has my car got?? ineedmoneyspentonmeitus. Quote Share this post Link to post Share on other sites
