Forrest 35 Report post Posted December 11, 2008 Replacing the rack ends in my e30, got one side off easy as with a monkey wrench, the other side (drivers side) wont budge at all. Its soaking in penetrating fluid right now, anyone got any tips as to getting these off? Any help is appreciated Cheers, Nathan Quote Share this post Link to post Share on other sites
|ncary 0 Report post Posted December 11, 2008 The ball joint? You can be responsible and get a ball joint fork, and it works well, Orrrrrrr.. Get your hammer and wack that bolt sideways a few times to loosen it up first and then pound it out. Protect the threads with whatever you have laying around ha. Replacing the whole control arm is the usual thing to do, much less hassel and then you've done the ball joints on the chassis as well :thumbsup: Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted December 11, 2008 The ball joint? You can be responsible and get a ball joint fork, and it works well, Orrrrrrr.. Get your hammer and wack that bolt sideways a few times to loosen it up first and then pound it out. Protect the threads with whatever you have laying around ha. Replacing the whole control arm is the usual thing to do, much less hassel and then you've done the ball joints on the chassis as well :thumbsup: Not the ball joint, the threaded piece after the balljoint that joins to the center steering rack piece. Can provide pics if everyone is lost Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted December 11, 2008 (edited) Get your hammer and wack that bolt sideways a few times to loosen it up first and then pound it out. Protect the threads with whatever you have laying around ha. Replacing the whole control arm is the usual thing to do, much less hassel and then you've done the ball joints on the chassis as well :thumbsup: If you use the same hammer, and wack the strut where the ball joint passes through, you won't damage anything except your hearing. (edit) For the other problem, bigger monkey wrench. Edited December 11, 2008 by CamB Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted December 11, 2008 may have to take photos for this one, havnt explained very well lol Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 11, 2008 may have to take photos for this one, havnt explained very well lol I know what you are talking about. Its the rack end joint or inner tie rod. We have a special tool to do them, its a special tube crowsfoot... we could do it for you Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted December 11, 2008 I know what you are talking about. Its the rack end joint or inner tie rod. We have a special tool to do them, its a special tube crowsfoot... we could do it for you hahaha you sure could glenn, maybe i shud just jump in my teleporter up to auckland may just have to perservere with the monkey wrench, how hard can it be its only a 18 y/o e30 Quote Share this post Link to post Share on other sites
mops 4 Report post Posted December 23, 2008 get bigger wrench ! more leverage ! make sure you wont break anything Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted December 24, 2008 hahaha you sure could glenn, maybe i shud just jump in my teleporter up to auckland may just have to perservere with the monkey wrench, how hard can it be its only a 18 y/o e30 Duno how much space u got down but you could use a cheater bar (slip a bar over the wrench handle and apply force futher up the bar), thus creating more torque and less pain in your arm. Other than that you can try heating it up with a blowtorch (responsibly ) Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted December 24, 2008 haha i tried all options, in the end my mate borrowed a rack end remover tool that goes on the end of a socket wrench, worked like a charm, thanks tho man Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted December 24, 2008 haha i tried all options, in the end my mate borrowed a rack end remover tool that goes on the end of a socket wrench, worked like a charm, thanks tho man Thats good you got it off. I spent the best part of 6 hours removing all the bolts/nuts holding my previous diff in and iv still got the scars to show lol. Good luck with ur project Quote Share this post Link to post Share on other sites
