m325i 732 Report post Posted September 14, 2004 The speedo dash light has never worked, but it works when u slap the dash, everytime. 6 months later now it doesnt. Any info available on changing bulbs? Also under the steering column by your knees, the under dash cover, are these easily available from wreckers etc.? Cher Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted September 14, 2004 (edited) the instrument panel is easy to take out. remove knee thingee. reach under and undo the two grup screws from beind, one each side of the wheel with you fingers. 6 screws, 4 at the bottom and 2 at the top. to remove trim. there are 3 clips behind the panel. disconnect those. you should beable to take the light bulbs out from there Edited September 15, 2004 by bumpstop325 Quote Share this post Link to post Share on other sites
*sic 1 Report post Posted September 15, 2004 if the buld is blown it wont go, period so you bashing it for ages to get it going means that it wasnt blown just a bad connection, ya dig? Quote Share this post Link to post Share on other sites
m325i 732 Report post Posted September 15, 2004 Cher bumpstop. if the buld is blown it wont go, period so you bashing it for ages to get it going means that it wasnt blown just a bad connection, ya dig? i always had to bash. now bashing doesnt work. might not be a bulb, but shouldn't that be first check point? Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted September 15, 2004 you still need to take it out to check the connections. Quote Share this post Link to post Share on other sites
