isis 16 Report post Posted December 18, 2008 e46 318i - need to warm up before driving off, if not it'll just stall and the steering locks! pretty friggin dangerous! but if you warm it up before driving it off, its all fine. Had it hooked up to diagnostics a few times and no errors to be found. Ideas? Cheers Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted December 18, 2008 e46 318i - need to warm up before driving off, if not it'll just stall and the steering locks! pretty friggin dangerous! but if you warm it up before driving it off, its all fine. Had it hooked up to diagnostics a few times and no errors to be found. Ideas? Cheers is it a auto? Quote Share this post Link to post Share on other sites
isis 16 Report post Posted December 18, 2008 ahuh - it jumps from D as well... Quote Share this post Link to post Share on other sites
stylish_division 0 Report post Posted December 18, 2008 e46 318i - need to warm up before driving off, if not it'll just stall and the steering locks! pretty friggin dangerous! but if you warm it up before driving it off, its all fine. Had it hooked up to diagnostics a few times and no errors to be found. Ideas? Cheers i have similar problem, but only does it when car is warm, and idleing.. starts back up no problem though. Had it scanned and no problems, compression and everything perfect. Quote Share this post Link to post Share on other sites
*Glenn* 855 Report post Posted December 18, 2008 If it was checked properly it should be able to be diagnosed. If there are no fault codes, its likely to be the air mass sensor. You need to drive it with the scanner hooked up and check live data. Another possibility would be the crankcase ventilator valve or breather hose from the same valve. Quote Share this post Link to post Share on other sites
