Five Star 0 Report post Posted December 23, 2008 I'm replacing my sump gasket on my e21 320/6 (m20b20) and I'm having a few problems with a few bolts that I can't get tools to because of the steering rack and bell housing. I've got 22 bolts out, and I can only see one more but I'm told there's 24. Anyone had experience with this before? Quote Share this post Link to post Share on other sites
williams 0 Report post Posted December 23, 2008 have u removed the 2 bolts that are situated in the g/box bell housing? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 23, 2008 Dont use a gasket...they only supply cork now & they split between the bolt holes. Clean thoroughly with white spirits and use Eurothane sealant.. Not silicon..you get it from Panel Beating supplies. Use the grey for a cleaner look. I've explained all this in a previous thread, someone might be able to dig it out for you. If you like...give me a call Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted December 23, 2008 (edited) someone might be able to dig it out for you. http://www.bimmersport.co.nz/forums/index....st&p=146553 Glenn - if its not too much hassle could you please post the exact brand/product. Thanks, Cam Edited December 23, 2008 by CamB Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted December 23, 2008 There are 25 bolts. And hmmm, I have used the cork gasket in 2 different applications along with an RTV sealant and both have been fine. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 23, 2008 http://www.bimmersport.co.nz/forums/index....st&p=146553 Glenn - if its not too much hassle could you please post the exact brand/product. Thanks, Cam Carbond 940FC Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 23, 2008 There are 25 bolts. And hmmm, I have used the cork gasket in 2 different applications along with an RTV sealant and both have been fine. I do this for a living... you dont need to listen...others might. The cork gaskets are hopeless Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted December 23, 2008 Carbond 940FC Thanks - much appreciated. Quote Share this post Link to post Share on other sites
Five Star 0 Report post Posted December 23, 2008 I've got a gasket from gavin at euro italian.. I'll give you a call glen. Didn't expect you to be working on xmas eve though.. Quote Share this post Link to post Share on other sites
Five Star 0 Report post Posted December 23, 2008 A big thanks to Glen for sorting me out on the phone. Time to have a go at the sump again.. I can see problems with it still being in the car and the gearbox. Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted December 24, 2008 i dont know my e21's, but why didnt you just take bonnet off, loosen engine mounts, bottom bolt and top bolt, jack engine up? or there still not enough room to remove sump ? No engine hoist ? Thats how i saved my frustration Quote Share this post Link to post Share on other sites
Five Star 0 Report post Posted December 24, 2008 The last two bolts were hidden by a plate which just required two bolts to be removed so it swung out of the way. Everything put back together OK and minus a small oil leak (oops, missed a bit...) it's all fine. Good enough that I finally got the car started after having it not running for a year Quote Share this post Link to post Share on other sites
