Guest FrantiC
e30 stuff
Guest FrantiC
Still trying to get rid of a few odds and ends.
m20 oil pan $80
Chrome door surround trim (fits both 2 door and 4 door , This is the trim that fits on the actual car not doors). $40 for both.
4.45 lock diff, Has a broken rear cover so would need another swapped on. $150
Rear left PRE FACELIFT tail light. $30
Side mirrors, Diamond black metallic, bit of paint pealing off but glass in good condition. $20 each.
e30 fan clutch and orange fan. $20
Rear Right Coupe window and all surround. Direct "bolt on" basically. Can supply the latch also. $20
Various seatbelts, 2 Full sets and various others from a coupe. Will sell separate if required. Offers.
Have headrests in the grey cloth/ black vinyl, 2 in good condition. Rear shock covers and good mounts. Also have some other bits and pieces from here and there. If you are local hit me up and ill pull my boxes of stuff out for a look if you like. Can strike some pretty damn cheap deals on stuff.
m20 starter motor ?
Thanks heaps
What bout fuel pressure regulator for m20b25?
thanks
Guest FrantiC
m20 starter motor ?
Thanks heaps
thanks
Yep I got a couple startermotors lying around.
And yep I got a FPR somewhere that I took off a 325i motor fuel rail that I used and replaced the FPR, didnt know if it were good or bad but replaced it mine anyways.
Make an offer.
Guest FrantiC
text or ring me on 027 7739761.
dont really have that much, basically what is listed above.
