Ben
Apexi SAFC/NEO
Hey Im looking for an Apexi SAFC or Apexi AFC NEO so if you happen to have one
and want to sell it PM me
Cheers Ben
Apexi V/SAFC's give you the ability to adjust the amount of fuel that the ECU injects into the engine by alterting the signal from the AFM to the ECU.
They also show things like RPM, TP and battery voltage..
Google is your freind :D . I should've done that in the first place
But what does been want one for ??? Is he doing a project ??
Haha indeed it is..
We used them to correct AFR's (as best we could without a dyno) when we couldnt afford a fully fledged aftermarket ECU. IMO it doesnt makes sense financially when nowadays you can pick up a 2nd hand Link, Motec or whatever your flavor for easily under a grand and do 4 times as much..
No idea what he wants it for tho!
There is a NEO on trademe at the moment ~$550 IIRC
Have you had a look at the MAP-ECU yet??
Yea I got that one on my watchlist haha
havent checked out mapecu yet but i will do
I just want one to tune the fuel down in my E36. Heres a bit of info on what Ive done Link
