325jones 0 Report post Posted January 20, 2009 (edited) e36 325i 5 speed when starting off if i put my foot down anymore then 20% i get a single knock or a click sound from my rear right side (its just the one knock each time i take off) diff??? the cv joints on my axles?? any help and cheap places for parts in chch cheers goin to have it over a pit 2day at work what should i be lookin 4? Edited January 20, 2009 by 325jones Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted January 20, 2009 Id say bushes Quote Share this post Link to post Share on other sites
325jones 0 Report post Posted January 20, 2009 Id say bushes like torque rod bushes??? or sway bar how would i test them? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 20, 2009 e36 325i 5 speed when starting off if i put my foot down anymore then 20% i get a single knock or a click sound from my rear right side (its just the one knock each time i take off) diff??? the cv joints on my axles?? any help and cheap places for parts in chch cheers goin to have it over a pit 2day at work what should i be lookin 4? I'd be checking hub nut, axle bolts (diff end),calliper mounts, disc pads...they could be moving in the calliper..especially check the inner pad and make sure the clip holding the pad inside the calliper piston is not broken. If all thats good check for loose suspension bolts, shock mount, or control arm mounts and bushes. Quote Share this post Link to post Share on other sites
325jones 0 Report post Posted January 23, 2009 (edited) e36 325i 5 speed when starting off if i put my foot down anymore then 20% i get a single knock or a click sound from my rear right side (its just the one knock each time i take off) diff??? the cv joints on my axles?? any help and cheap places for parts in chch cheers goin to have it over a pit 2day at work what should i be lookin 4? got it up on axle stands at moment cant see anything out of the blue, had brakes apart both sides they look all good, all bushes look good, cant feel any play in the cv (but how would i check them???))) but the diff its not really noisey but its got a bit of a rumble anyone in the chch islington area that knows a bit about them able to cum and have a look. also i want to check the diff oil is it a 12 or 14mm allen key?? my set only goes up to 10mm also whats the tool used to remove the alxes off the diff??? cheers all Edited January 23, 2009 by 325jones Quote Share this post Link to post Share on other sites
325jones 0 Report post Posted January 24, 2009 got it up on axle stands at moment cant see anything out of the blue, had brakes apart both sides they look all good, all bushes look good, cant feel any play in the cv (but how would i check them???))) but the diff its not really noisey but its got a bit of a rumble anyone in the chch islington area that knows a bit about them able to cum and have a look. also i want to check the diff oil is it a 12 or 14mm allen key?? my set only goes up to 10mm also whats the tool used to remove the alxes off the diff??? cheers all bump still cant work it out thinkin of removing the diff but not 100% sure cheers Quote Share this post Link to post Share on other sites
Ben 0 Report post Posted January 25, 2009 Check the subframe mounts. I had the same problem and just left it, until one day it made a really loud thump. Finally decided to check it out and i had torn three of the four mounts clean off the body!! (I still have the chunks of steel from the chassis, kinda like my keepsake haha) I ended up welding in thicker steel mounting points and a bit of extra bracing It wasnt the hardest job but it was a bit of a PITA and would have been alot easier if i had of caught it earlier. Though thats probably the worst case scenario It could just be the bushes on the subframe mounts. Quote Share this post Link to post Share on other sites
325jones 0 Report post Posted January 25, 2009 Check the subframe mounts. I had the same problem and just left it, until one day it made a really loud thump. Finally decided to check it out and i had torn three of the four mounts clean off the body!! (I still have the chunks of steel from the chassis, kinda like my keepsake haha) I ended up welding in thicker steel mounting points and a bit of extra bracing It wasnt the hardest job but it was a bit of a PITA and would have been alot easier if i had of caught it earlier. Though thats probably the worst case scenario It could just be the bushes on the subframe mounts. yer had a wee look around that part, couldnt see anything wrong but i would not know what to look for 4, but after my talk with glenn on the fone i have chosen to bite the bullet and take it in to the shop, i hope its nice and cheap, get them to find it and then i will fix it, Quote Share this post Link to post Share on other sites
