danthaman01 0 Report post Posted January 20, 2009 Hey Where can you get under drive pulleys in NZ? Do they give a good gain in power on the M50 motor? any help appreciated cheers Dan Quote Share this post Link to post Share on other sites
320guy 0 Report post Posted January 21, 2009 Dont think you will find any in NZ, but you will be lucky if they give you a noticable power increase. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 21, 2009 (edited) The pulleys will make your wallet lighter...dont know what that will equate to in HP gains though BTW: Seriously, I have a waterpump one here if you want it.... alluminium and FREE You'll need to get a shorter drive belt for it though Edited January 21, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
briancol 3 Report post Posted January 21, 2009 The pulleys will make your wallet lighter...dont know what that will equate to in HP gains thoughGlenn, haven't you heard about power to weight ratio? If his wallet is lighter the car must go faster. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 21, 2009 Check my edits Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 22, 2009 Can i ask what under drive pullys are? Never heard of them. Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted January 22, 2009 (edited) Can i ask what under drive pullys are? Never heard of them. Different "ratio" pulleys for like your alternator etc, Good for engines that see higher revs more often. They run the alternator or whatever it is a slower rate than stock. Edited January 22, 2009 by FrantiC Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 22, 2009 Different "ratio" pulleys for like your alternator etc, Good for engines that see higher revs more often. They run the alternator or whatever it is a slower rate than stock.Oh i see. can't imagine it would be that necessary? Quote Share this post Link to post Share on other sites
danthaman01 0 Report post Posted January 22, 2009 cheers guys was just looking in performance BMW and they listed them as a must do for a m50 after exhaust and intake mods, they were making claims of up to 10 hp Quote Share this post Link to post Share on other sites
morerevsm3 7 Report post Posted February 8, 2009 on an E36 M3, replace the crank pulley with an E46 M3 pulley, cheap and underdrives all accessories Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted February 14, 2009 The belt drives the Alternator, Air con and Water pump. The total power required to drives these would may be get close to 5kW in the worst case. About 80% of this would be the Air con Reducing the pulley ratio by 10% would reduce this by 10% or .5 kW Turning the air con off will reduce it by 80% The magic (lies) is in the marketing the truth is in basic physics and maths. i make under-drive pulleys for many different vehicles,the alternator can rob 7-12 hp and water pump around he same to which is why race cars run an electric pump and the alternator runs off the drive shaft. they don't go to these degrees if there wasn't a noticeable gain. water pump conversion to electric on a small block is worth 20hp at the wheels,cant complain about that. the other reason apart from power gains( which are real !!) is with the water pump it stops it cavitating at higher rpm to aid cooling. you notice the gain everywhere not just at high rpm. so there's maybe something in that magic every little thing helps when playing with na,smaller lighter etc maybe only 5-6 hp here and there but combined together could at up to a noticable gain. I'm looking at making my own multi throttle body setup on my m40, i only listen to those who can prove to me certain things arnt worth the gain. then there's those with their heads stuck in the sand,just cause its a bmw doesnt mean it cant be done Quote Share this post Link to post Share on other sites
