haydenz 0 Report post Posted January 26, 2009 Ok. I will start off with a little bit of history about my 1991 525i E34. Vehcile was frequently serviced by its first New Zealand owner. Nothing went wrong with the car when the previous owner had it. I purchased the car at 148,000k's in August 2008. Since I have owned the car, I have had to replace the following: Water pump Thermostat Break light switch Radiator Alternator Automatic Transmission (Jatco) Idler Battery Radiator hose I am now getting a ticking noise from my M50B25 engine!! Sounds like a diesel vehicle while idling! It seems to dis-appear once the vehicle is up to about 2500rpm. Any suggestions?? I'm sick of paying for things to be fixed and being ripped off as I am not a car person. Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted January 26, 2009 Ok. I will start off with a little bit of history about my 1991 525i E34. Vehcile was frequently serviced by its first New Zealand owner. Nothing went wrong with the car when the previous owner had it. I purchased the car at 148,000k's in August 2008. Since I have owned the car, I have had to replace the following: Water pump Thermostat Break light switch Radiator Alternator Automatic Transmission (Jatco) Idler Battery Radiator hose I am now getting a ticking noise from my M50B25 engine!! Sounds like a diesel vehicle while idling! It seems to dis-appear once the vehicle is up to about 2500rpm. Any suggestions?? I'm sick of paying for things to be fixed and being ripped off as I am not a car person. quite comon for the hydrolic lifters to get noisey . changing the oil can somtimes quieten them down a bit .(is it louder when first started?) otherwise i think you have to replace them . i have spares if needed. cheers brent Quote Share this post Link to post Share on other sites
williams 0 Report post Posted January 26, 2009 check if all spark plugs are tight Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted January 27, 2009 Exhaust leak can do similar, especially if it is coming from the manifold off the head or at the downpipe flange. Quote Share this post Link to post Share on other sites
haydenz 0 Report post Posted February 10, 2009 quite comon for the hydrolic lifters to get noisey . changing the oil can somtimes quieten them down a bit .(is it louder when first started?) otherwise i think you have to replace them . i have spares if needed. cheers brent check if all spark plugs are tight Exhaust leak can do similar, especially if it is coming from the manifold off the head or at the downpipe flange. Thanks for your help guys! It just fixed itself?!?! Good enough for me! Quote Share this post Link to post Share on other sites
