mystery39 0 Report post Posted January 26, 2009 Hi, I'm having an issue with the boot lock on my E39 - when I try to open the boot using the release on the outside or the one by the drivers foot I get a loud whirring noise (sounds like a cog slipping repeatedly) and the boot won't open. I can still open it with the key, but no joy from the handle/release latch. Can anyone help me with this? Thanks! Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 26, 2009 mystery39 said: Hi, I'm having an issue with the boot lock on my E39 - when I try to open the boot using the release on the outside or the one by the drivers foot I get a loud whirring noise (sounds like a cog slipping repeatedly) and the boot won't open. I can still open it with the key, but no joy from the handle/release latch. Can anyone help me with this? Thanks! The finger tip grommet under where the number plate lights are, is probably jamming the micro switch. Check the grommet. Take the number plate off and flick the assembly out with a small screw driver and refit the grommet correctly. Refit and it should work. Before you refit it check the micro switch is working... it should make the opening solenoid click Quote Share this post Link to post Share on other sites
Lubed 55 Report post Posted January 27, 2009 Sounds like your boot lock actuator has stripped out, pull the boot lid trim off and check its operation with the boot up ,close the latch manually by hand with a screwdriver then push the opening button.Check for the grinding noise from the actuator. Quote Share this post Link to post Share on other sites
vandervanvan 0 Report post Posted January 27, 2009 streetmagic has hit the nail on the head . your central locking motor has had it !! Quote Share this post Link to post Share on other sites
RvT 9 Report post Posted January 27, 2009 vandervanvan said: streetmagic has hit the nail on the head . your central locking motor has had it !! +1 If shopping new, try the dealer and also get a price from these guys ... http://www.motormec.co.uk/ Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 27, 2009 (edited) Jeebus, I should read these threads more thoroughly.. than just flicking over them. If you are getting the noise it would probably be the solenoid (actuator) I have a good second hand one here. $75 if you want it. New ones have gone up in price now because the latch and actuator come as one now, not seperate.. The grommet I was talking about is one of the most common problem because people tend to lift the boot with there fingers and push the grommet out of alignment which jams the micro switch. Edited January 27, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
mystery39 0 Report post Posted January 27, 2009 Great, thanks all for your help. No worries Glenn, I managed to isolate the motor as the problem, definitely interested in purchasing yours if possible! Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 27, 2009 mystery39 said: Great, thanks all for your help. No worries Glenn, I managed to isolate the motor as the problem, definitely interested in purchasing yours if possible! Just give me a call Quote Share this post Link to post Share on other sites
mystery39 0 Report post Posted January 29, 2009 *Glenn* said: Just give me a callHi Glenn, thanks for sorting our the lock motor for me. However I've run into trouble while fitting it - the electrical connection from the release switch on the car has a 6 pin connector (although only 5 wires) while the lock motor has a 4 pin socket. How can I get around this? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 29, 2009 mystery39 said: Hi Glenn, thanks for sorting our the lock motor for me. However I've run into trouble while fitting it - the electrical connection from the release switch on the car has a 6 pin connector (although only 5 wires) while the lock motor has a 4 pin socket. How can I get around this? Well its the wrong one for your car...It is for a E39 but there are two types. I'll have to give you a credit and you'll have to get the correct one for your car. I was hoping you were going to come with the car as I told Chris to fit it for you when you came in. I can get you a new one by chassis# less 10% or you'll have to try around to get a 2nd hand one. Quote Share this post Link to post Share on other sites
mystery39 0 Report post Posted February 3, 2009 *Glenn* said: Well its the wrong one for your car...It is for a E39 but there are two types. I'll have to give you a credit and you'll have to get the correct one for your car. I was hoping you were going to come with the car as I told Chris to fit it for you when you came in. I can get you a new one by chassis# less 10% or you'll have to try around to get a 2nd hand one. Ah. I see. That would explain it. I'll bring the car in next week if I get time. Quote Share this post Link to post Share on other sites
