mammoth 0 Report post Posted January 31, 2009 Hi, Just started having trouble with the factory alarm going off more often than it should, certainly more than it ever did. I'm thinking this might be an indication to replace the car battery? I know that the factory indicator on the batt shows as 'black spot'. Anyone got any clues? Quote Share this post Link to post Share on other sites
RvT 9 Report post Posted January 31, 2009 Black E39 said: Hi, Just started having trouble with the factory alarm going off more often than it should, certainly more than it ever did. I'm thinking this might be an indication to replace the car battery? I know that the factory indicator on the batt shows as 'black spot'. Anyone got any clues? Had the same issue with my e34 way back. Alarm would sound off in the middle of the night. We replaced the battery and all was fixed Quote Share this post Link to post Share on other sites
mammoth 0 Report post Posted January 31, 2009 RvT said: Had the same issue with my e34 way back. Alarm would sound off in the middle of the night. We replaced the battery and all was fixedCheers. I was hoping that wasn't the case - bloody expensive those batteries. Quote Share this post Link to post Share on other sites
allan 295 Report post Posted January 31, 2009 Black E39 hi! They are expensive if you go genuine but not to bad for a good quality after market one. Match the capacity of the battery with what you have now I was told to do.As the E39 has a lot of behind the scene things going on that one is not aware of. Allan Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted January 31, 2009 allan said: They are expensive if you go genuine but not to bad for a good quality after market one. Match the capacity of the battery with what you have now I was told to do.As the E39 has a lot of behind the scene things going on that one is not aware of. Indeed, never fit an under-rated battery to a car. It will cost you more as the smaller battery will fail sooner and leave you stranded somewhere. Always fit the a battery meeting or exceeding the original battery's capacity And with a high-quality car like a BMW, make sure you fit a high quality battery. Quote Share this post Link to post Share on other sites
williams 0 Report post Posted January 31, 2009 have someone scan the alarm memory to see what the fault is causing the alarm to sound Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 1, 2009 (edited) An E39 takes either a Din 65 or Din 85 Callcium Euro battery If your in Auckland I can help with a deal on a new battery with 3 year warranty Edited February 1, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
mammoth 0 Report post Posted February 1, 2009 *Glenn* said: An E39 takes either a Din 65 or Din 85 Callcium Euro battery If your in Auckland I can help with a deal on a new battery with 3 year warranty Yeah DIN65, I get a pretty good deal on Endurant. Out of interest I checked out the dealer - double the price.Is it worth scanning the computer for a fault? Is this a dealer thing or can most Euro specialists do this? Quote Share this post Link to post Share on other sites
vandervanvan 0 Report post Posted February 2, 2009 i agree with 2 slow , have the vehicle diagnosed , there my be nothing wrong with the battery . i know bonnet switches are a major cause of false alarms . have it checked out !!! Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 2, 2009 [quote name='Black E39' date='Feb 1 2009, 06:04 PM' post='220084' Is it worth scanning the computer for a fault? Is this a dealer thing or can most Euro specialists do this? To be absolutely sure...yes. If your battery is showing black & not green, the charge rate is OK and there is no current draw when the vehicle is shut down... replace the battery. Best get a specialist to do these checks though. Quote Share this post Link to post Share on other sites
