Guest FrantiC Report post Posted January 31, 2009 There are both blue and brown sensors on my thermostat housing. I need to replace either one or both (might do both depending on cost). Which one is for engine temp, For the ECU? And which one is for the cluster temp gauge? When I turn the key to ignition, the temp on the cluster goes to the 3rd line, or the 1st mark. Never moves at all. I assume the sensor is crapped out? Quote Share this post Link to post Share on other sites
Eagle 1773 Report post Posted February 1, 2009 Brown sensor for the gauge cluster Blue for the coolant temp sensor If replacing the sensor doesn't work try taking out the gauge cluster and checking gauge contact points Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted February 1, 2009 Brown sensor for the gauge cluster Blue for the coolant temp sensor If replacing the sensor doesn't work try taking out the gauge cluster and checking gauge contact points Cheers. Probably doesn't help I cut the wires for the brown one and "extended" them as it was way to short to plug into the sensor. Picture for reference. Note where the brown sensor is and where I have cut the wires and temporarily taped them together (they will be properly crimped). Could be my half-ass job of extending the wires or something ? Quote Share this post Link to post Share on other sites
Eagle 1773 Report post Posted February 1, 2009 Just wondering why your temp sensor is mounted where it is. Ever bmw ive seen has it next to the coolant sensor Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted February 1, 2009 Just wondering why your temp sensor is mounted where it is. Ever bmw ive seen has it next to the coolant sensor Yeah I tried moving it where they normally go but this one seems way bigger and when I moved it there the fuel rail go in the way and wouldn't fit in properly. That was the original spot it was mounted and the only hole it will fit. Maybe wrong sensor? Quote Share this post Link to post Share on other sites
Eagle 1773 Report post Posted February 1, 2009 I think so. Here's what suppose to look like. Id buy a new one put it in proper place Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted February 1, 2009 that big one is for a cold start injector(its a thermo time switch ,not a temp senor) . your face lift system doesn't need that any more . just put a std temp sensor in . Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted February 1, 2009 I think i have a spare that looks like the one Eagle has shown. It only has 1 prong though. Is that normal? Quote Share this post Link to post Share on other sites
Eagle 1773 Report post Posted February 1, 2009 (edited) Ah yeah cold injectors, was wondering what that spare thermostat housing bolt was for. Yeah temp sensor is only one prong Edited February 1, 2009 by Eagle Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted February 2, 2009 Ah yeah cold injectors, was wondering what that spare thermostat housing bolt was for. Yeah temp sensor is only one prong you need the newer temp sensor with 2 pins . old type only had one spade terminal Quote Share this post Link to post Share on other sites
Eagle 1773 Report post Posted February 2, 2009 I know the plug has 2 terminals but never seen a 2 prong type sensor. Parts number for my car all bring up temp sensor with one prong. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted February 2, 2009 I know the plug has 2 terminals but never seen a 2 prong type sensor. Parts number for my car all bring up temp sensor with one prong.thats because you are using a chasis number from a preface lift car instead of the face lift model where the engine ecu type came from.any way they look just like the other small one with 2 pins . have instock . in papakura 021433600 Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted February 2, 2009 I pulled the big one out and put the small one I had in. See how that goes when I go for a drive. I assume I would need the 2prong one as the plug is 2wire but I will see how she goes. The big sensor has "VDO" on it though. Not sure if that means it is related to the VDO instrument cluster temp gauge? Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted February 2, 2009 fwiw sometimes the connection to the sensors are corroded and that makes read wrong Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted February 2, 2009 I pulled the big one out and put the small one I had in. See how that goes when I go for a drive. I assume I would need the 2prong one as the plug is 2wire but I will see how she goes. The big sensor has "VDO" on it though. Not sure if that means it is related to the VDO instrument cluster temp gauge? the big one actual has a bi metal thermistor . which activates the cold start injector on pre face lift models only when engine is cold and in start position Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted February 2, 2009 the big one actual has a bi metal thermistor . which activates the cold start injector on pre face lift models only when engine is cold and in start position Oh ok. Well I just went for a long drive now and the gauge only moved up to the blue area and didn't go up at all. Looks like Ill have to get the proper 2 prong one at some stage. Cheers for the help guys Quote Share this post Link to post Share on other sites
Eagle 1773 Report post Posted February 2, 2009 thats because you are using a chasis number from a preface lift car instead of the face lift model where the engine ecu type came from. any way they look just like the other small one with 2 pins . have instock . in papakura 021433600 I was using my E30 chassis number which is a face lift car. Not sure what the second prong does but my gauge is working fine. Quote Share this post Link to post Share on other sites
