ispansbab 0 Report post Posted February 16, 2009 Hi All, I'm looking at a 1987 NZ new 318i, 2-door coupe, 4-cyl 1800cc. Is this car supposed to have a cambelt or camchain? The current owner believes it is a chain, but i think it's got a belt. What other issues should I look out for on this car? It's nice and straight, but feels a tad bit sluggish on take off. Cheers Quote Share this post Link to post Share on other sites
Cale 36 Report post Posted February 16, 2009 If its '87 the motor will be an m10, which runs a camchain. Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted February 16, 2009 but feels a tad bit sluggish on take off. is it an auto? it is a 318 after all - it probably feels a bit sluggish all the time Quote Share this post Link to post Share on other sites
ispansbab 0 Report post Posted February 16, 2009 Thanks for the input guys. Yes it's an auto. This is the first time i've driven an E30, does the gas pedal really feel heavy on these cars or is the spring just too hard? I found myself applying a lot more oomph than i normally would to get the car to accelerate. Where do i check the engine code, would it be on the VIN plate in the engine compartment? Had a bit of ruist on the inside of the boot, is this something that would fail the WoF? Cheers fellas! Quote Share this post Link to post Share on other sites
ispansbab 0 Report post Posted February 16, 2009 Can i tell the engine code from the VIN/Chassis #? Quote Share this post Link to post Share on other sites
euroitalian 63 Report post Posted February 16, 2009 Can i tell the engine code from the VIN/Chassis #? Not directly, but if you enter the last 7 digits into BMW parts program like: http://www.realoem.com/bmw/select.do it will tell you which engine was fitted. Quote Share this post Link to post Share on other sites
ispansbab 0 Report post Posted February 16, 2009 Awesome. Worked a treat. It's a Jan 87 built car. M10 engine. Thanks for that link! Quote Share this post Link to post Share on other sites
tire 10 Report post Posted February 16, 2009 (edited) Throttle was also stiff compared to jappas in my e30. I liked it. edit, by throttle I mean pedal Edited February 17, 2009 by tastic Quote Share this post Link to post Share on other sites
ispansbab 0 Report post Posted February 16, 2009 Hey thanks, stiff is the word to describe it. Quote Share this post Link to post Share on other sites
320guy 0 Report post Posted February 17, 2009 My pedal is stiff aswell, but then again my mates e30's pedal was alot lighter. Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted February 17, 2009 Stiff pedal is easy fix. Spray some CRC or WD40 or Inox etc in where the throttle cable ends on the engine side Quote Share this post Link to post Share on other sites
ispansbab 0 Report post Posted February 17, 2009 How much do you guys reckon it's worth? Silver (straight body, no dings) Cloth interior, very tidy, just a tear in the middle of the driver's seat, small crack on dash NZ new M10 motor, done 145ks 1987 Quote Share this post Link to post Share on other sites
Cale 36 Report post Posted February 17, 2009 How long is a piece of string? Hard to say without pics etc... 1.5-2K?? Seeing as its a 2-door. Quote Share this post Link to post Share on other sites
ispansbab 0 Report post Posted February 17, 2009 Fair enough. I've passed on it as it's a 2-door and auto. Looks nice though. Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted February 18, 2009 I am not a fan of the stiff bmw throttles - I always take half a turn to a full turn off the spring on the throttle body to make it less stiff - still returns/snaps closed fine. Less wear/strain on the cable to. Quote Share this post Link to post Share on other sites
ispansbab 0 Report post Posted February 25, 2009 Wow, offered to me for $1200 and i turned it down. sold on TM for $2870 Quote Share this post Link to post Share on other sites
