Chalk 0 Report post Posted February 21, 2009 Talking about my m325. The most annoying thing in my life<_< Ok my car is off the road at the moment as its got no warrent... But the battery has died and since thats happened the locking is all messed up? The drivers door will unlock using the key but not lock, it will also lock from the inside but not unlock. The passenger door locks are kinda opposite. Also seeing the car battery is dead theres no central locking so i can't open the petrol hatch? And I can't keep the car running to charge the battery because the car is running low on petrol? How do i open the petrol hatch and anyone have any ideas on the what has gone wrong with the locks? Thanks a lot for any input Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 21, 2009 The locking system requires a good battery... It doesnt work off oxygen Quote Share this post Link to post Share on other sites
Chalk 0 Report post Posted February 21, 2009 *Glenn* said: The locking system requires a good battery... It doesnt work off oxygen Haha thanks for the tip off.. But like... I only have 1 key... The battery is practically new but i can't keep the car running long enough to charge the battery with the amount of petrol in the car... And also i can't make use of the central locking with the key in the ignition... Any ways around this? Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted February 21, 2009 (edited) Remove the central locking unit from the fuel flap. Go into your boot, Pull the side carpet trim away and up by the wheel well is the central locking unit held there by 2 screws/bolts. Undo and pull it out. Problem solved (I mean now you can put fuel in, charge up the battery and re-install it). Edited February 21, 2009 by FrantiC Quote Share this post Link to post Share on other sites
Chalk 0 Report post Posted February 21, 2009 FrantiC said: Remove the central locking unit from the fuel flap. Go into your boot, Pull the side carpet trim away and up by the wheel well is the central locking unit held there by 2 screws/bolts. Undo and pull it out. Problem solved (I mean now you can put fuel in, charge up the battery and re-install it). Oh thanks a lot.. Should all the locking of the car go back to normal once the battery is charged up etc? Quote Share this post Link to post Share on other sites
Siani 0 Report post Posted February 21, 2009 It should, it did with mine. Quick question, why don't you take the battery out and out it on a charger? Quote Share this post Link to post Share on other sites
Chalk 0 Report post Posted February 22, 2009 Siani said: It should, it did with mine. Quick question, why don't you take the battery out and out it on a charger? Cause i don't have the use of a charger thanks a bunch! Quote Share this post Link to post Share on other sites
Chalk 0 Report post Posted March 4, 2009 Haha so thanks for the help on opening my fuel hatch! But now i don't know if the alternator is gone or the battery is gone to poos... How can i check? I took it for a really long drive but it didn't get really any charge! Thanks for any help much appreciated! Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted March 5, 2009 Take it to an auto sparky. They have testing gear which will tell you. You can take a guess and replace the alternator, but the only way to know for sure is to test it. Quote Share this post Link to post Share on other sites
Guest Spottswoode Report post Posted March 5, 2009 *Glenn* said: The locking system requires a good battery... It doesnt work off oxygen Vaccuum locks really should have been consigned to the "what were we thinking" file Quote Share this post Link to post Share on other sites
