volcanoblack
Need Help finding tyres
Hi All,
I am having trouble finding tyres here in New Zealand as all the models are different than in the US.
I have a '93 325i and just got a set of BMW Motorsport Double Spoke 1 wheels (17 x 7.5). Tyre size should be 225/45-17 as best as I can determine. (Car has 18" on it now.)
Can Johnno help me? Or can anyone recommend a good place to buy tyres that have name brands and good prices. Will also need to ship to Golden Bay, South Island. Need a set of four.
I do not want Champiro, Duran, or Nankang or other cheap Chinese tyres.
It appears that all season tyres are not used here at all, so I want a good tyre in the wet (and dry of course). I occasionally need to drive across the Takaka Hill in light snow.
Any suggestions?
Thanks all.
David Snook
Director
Auto Tyre Limited
09 8372501
021642220
This guys been great in getting me a pair of r888's. Havnt enquired about anything but toyo. They also freight
I have Toyo T1R on the M3 in that size (on the front), and they weren't that expensive (less than $500 a pair), and they seem fine. I don't personally think I can tell the difference between performance tyres (I can tell the difference between good and crap though).
Thanks for the replies, I have decided to go with a set of Kumho KU31's.
Although a summer tyre, they are apparently pretty good in light snow too. I do occasionally drive the Takaka Hill in winter and run into snow.
Cheers.
Thanks 3pedals,
The size you mention is 7.2mm (.283") smaller in diameter than the stock 205/60-15 and has a sidewall height of only about 94mm.
The 225/45-17 is 7.3mm (.287") larger in diameter and has a sidewall of approximately 101mm. The stock 60 series sidewall is 123mm.
I am trying to gain some sidewall height because I live in rural NZ with lots of rough roads and don't want a really harsh ride.
I looked at the 40 series, as on the early M3's, but thought I would trade off the width for the ride comfort.
Thanks.
No doubt the 40 series tyre will have a quicker response. All I can say is the 225/40-18 tyres that are on the car now I do not like. And my previous car, an Alfa had 40 series tyres on 17" wheels and I had many flat tyres - with no punctures or anything wrong with the tyres. So all I can assume is the bead was getting broken because the sidewall was too small. Our driveways here have quite a sharp edge.
Who knows, I may switch to the 235's next time.
The 18" wheels and Champiro's were on the car when I bought it and you are right, they did not work well at all. I believe the suspension is still stock although I have not had a chance to look closely. I have only had the car for a couple of months.
Also at my next tyre change on the 3 series I plan to go back to 235-40 on the front because the turn in on the 225-45's is too squishy for me.
He he, you'll be back on same size front and rear in no time at this rate.
