hot 520i 0 Report post Posted October 3, 2004 My 520i is taking a long time to get into drive. i can put it in to drive and rev the motor before it will go in to gear. what could this be? :drugs: Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted October 3, 2004 f**ked gearbox from attempted burnouts? time for a manual swap could be something else Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted October 3, 2004 whats it like going into reverse? does it do the samething? it sounds like the forward clutch packs are slipping. Quote Share this post Link to post Share on other sites
hot 520i 0 Report post Posted October 3, 2004 (edited) it goes good in reverse its just drive. how much for a forward clutch packs? Edited October 3, 2004 by hot 520i Quote Share this post Link to post Share on other sites
318is 0 Report post Posted October 3, 2004 Have your pressures and hoses looked at. Might be low oil or low pump pressure, or clutch packs. Either way - donen't sound too good i'm afraid.... time to sell?? or fork out for tranny out job?? Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted October 3, 2004 the forward clutch pack it a combination of about 6 or 7, 1mm steel disc's. depends on who you go to to get the job done should cost about 3-4 i have a M20 auto gearbox for you if you want to buy it. im coming up to h town this weekend. from memory the gearbox has only done about 105,00kms. also i have access to a pit in hams i can put it in for you. Quote Share this post Link to post Share on other sites
hot 520i 0 Report post Posted October 5, 2004 i talk to a guy at BMWorkshop he told me it will be up $2000 to fix. but it might just be $1200 he needs to look at so im taking it to him on friday. Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted October 5, 2004 (edited) bro, if yours is an M20 engine. i will sell you the gearbox for 200, and put it in for you for a 40oz THIS WEEKEND Edited October 5, 2004 by bumpstop325 Quote Share this post Link to post Share on other sites
