wolliver 1 Report post Posted March 7, 2009 is it ok to mix auto trans fluid? coz i knw mixing coolant with different brands of coolant can be risky Quote Share this post Link to post Share on other sites
*Glenn* 855 Report post Posted March 7, 2009 What proiducts are talking about? What type of car? .. Make?... Model?...Year ? Quote Share this post Link to post Share on other sites
wolliver 1 Report post Posted March 8, 2009 What proiducts are talking about? What type of car? .. Make?... Model?...Year ? its a 86 e30 Quote Share this post Link to post Share on other sites
bekker 7 Report post Posted March 11, 2009 Should be fine as long as you use the same grade / type. Quote Share this post Link to post Share on other sites
*Glenn* 855 Report post Posted March 11, 2009 (edited) Should be fine as long as you use the same grade / type. As a band aid maybe. I dont think thats the answer hes looking for...... I would suggest you get the leak checked and repaired, and service the transmission at the same time. The correct oil is G3, I would suggest you use G3 full synthetic. Edited March 11, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
wolliver 1 Report post Posted March 12, 2009 As a band aid maybe. I dont think thats the answer hes looking for...... I would suggest you get the leak checked and repaired, and service the transmission at the same time. The correct oil is G3, I would suggest you use G3 full synthetic.yup i did that and used that, there wasnt actually a leak, just replaced the radiator and some spilled out wen i did, and by some i mean a lot lol Quote Share this post Link to post Share on other sites
