C-130 Hercules 572 Report post Posted March 8, 2009 Hi all Trust someone out there can help. My aftermarket Sony radio is draining the car battery when the car is parked and all power switched off (key in 0 position). It draws about 0.4 A. When disconnecting I get the more agreeable 200 mA. What can I do to solve the problem (besides the obvious - ditching the radio)? Will a deep cycle battery with higher Amp rating help? Should I get the radio serviced? Let me know if you got any suggestions. Cheers Julian Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 8, 2009 Which one of your cars is doing this... and are you sure its the radio ?? Quote Share this post Link to post Share on other sites
lidistick 70 Report post Posted March 8, 2009 0.4A was the draw on my car for the interior light. It went down once the light went out. Totally fooled me. Check it again. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 8, 2009 (edited) Current draw must be checked with your multimeter wires out through the boot. The car must be locked and you need to wait for all the ECU's to go into sleep mode 15-30 minutes Edited March 8, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
rogan 18 Report post Posted March 9, 2009 One quick thought. Do you have a band expander? If so someone might have wired this to the +12v battery by mistake. Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted March 9, 2009 Off topic, but are those photos on your signature and avatar real? I like! Quote Share this post Link to post Share on other sites
C-130 Hercules 572 Report post Posted March 10, 2009 Thanks all for your comments - I have monitored draw over longer period and it comes down to between 60-90 mA which is still a bit much but whole lot less than 400mA. Will now go through all the fuses and see where it drains and that should fix the issue. And no, no band expander or other fancy gadgets in the car. Quote Share this post Link to post Share on other sites
