SRBMW
e30 Brake rotor special
E30 Vented front rotors $100 a pair
E30 Solid front rotors $100 a pair
E30 Solid rear rotors $100 a pair
or $190 for all four
$10 Freight North Island
$20 Freight South Island
Can do other rotors for all bmw models
[email protected]
Darren
Edited by SRBMW
Can you get a set of rear bilstein brake pads?
[email protected]
Darren
PM sent.
Hi, I Got an e30 do I need any mods to my brakes for these to work. they are standard. like the look of the solided ones.
On a side note, you will need to order the locator screws/bolts for the disks if they don’t come with the disks, the old ones are near impossible to remove without drilling out.
Wish I had have seen this special earlier as I just replaced mine.
Try CRC Penetrate, that stuff is liquid gold.
Let it soak for 10 min atleast, should come out. Other wise I sure someone on here would have some spare bolts lying around.
Tried that, hit it with a blow touch also… snapped two keys then hit it with the drill and a large hammer.
Would recommend buying two screws if doing the job, will make things a lot less frustrating.
These are standard replacement rotors so will bolt on,cheers
You dont need that locating screw. The wheel bolts hold the rotor on to the hub.
Yeah but if you take your wheels off for whatever reason your rotors will fall off and its a pain in the ass.
I think your calipers would hold them on.
Alot of cars don't have locator bolts .Some do Its just to take the stress on the base of the wheelstuds as sometimes the vibration causes damage
