kuryo193 0 Report post Posted March 14, 2009 (edited) E36 96' 320i sedan Im wondering if you guys can help me! Lately my rides bin idling quiet rough and I narrowed it down to the ICV, MAF and O2 sensors but thing now is it wont start! Is there some connection with the rough idling or is this going to be a fuel pump/relay as it turns over but does not fire.. I have just read to lift up the back seats to check so I will have a look but I was wondering if this was a common problem and hopefully there is a common way to fix and quick.. Edited March 14, 2009 by kuryo193 Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted March 14, 2009 if you give us info like year , shape model of the car that will help Quote Share this post Link to post Share on other sites
kuryo193 0 Report post Posted March 14, 2009 if you give us info like year , shape model of the car that will help E36 320i 96' sedan cheers Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 14, 2009 E36 96' 320i sedan Im wondering if you guys can help me! Lately my rides bin idling quiet rough and I narrowed it down to the ICV, MAF and O2 sensors but thing now is it wont start! Is there some connection with the rough idling or is this going to be a fuel pump/relay as it turns over but does not fire.. I have just read to lift up the back seats to check so I will have a look but I was wondering if this was a common problem and hopefully there is a common way to fix and quick.. I would consider from your explanation that you probably have 2 problems. The rough idle fault needs to be scanned to check what is wrong. The 2nd problem of not starting may be associated, however its likely to be the fuel pump, or water in the DME. I got your email this morning.. I suggest you give me a call. It would need to be towed to the workshop to repair Quote Share this post Link to post Share on other sites
topcat 11 Report post Posted March 14, 2009 that or the engine temp plug isnt doing it thing. first hoses in fuel thinking its super cold,then dies from flooding the plugs. glen what are you doing at 3.30 in the morning on the internet?? Quote Share this post Link to post Share on other sites
kuryo193 0 Report post Posted March 14, 2009 I would consider from your explanation that you probably have 2 problems. The rough idle fault needs to be scanned to check what is wrong. The 2nd problem of not starting may be associated, however its likely to be the fuel pump, or water in the DME. I got your email this morning.. I suggest you give me a call. It would need to be towed to the workshop to repair how much for towing out there from Mt Albert? not cheap Im guessing Quote Share this post Link to post Share on other sites
kuryo193 0 Report post Posted March 14, 2009 I gather it is the fuel pump as it does not "vibrate or make any noise".. the car does not turn much now which could be the battery dying on me.. turns over once and dies.. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 15, 2009 how much for towing out there from Mt Albert? not cheap Im guessing About $70.. check with Pakuranga Auto Transport Ph. 5761300 Quote Share this post Link to post Share on other sites
