jjs
E36 transmisson service - where to go in Akl?
Can anyone recommend a place to service the trannie on my 328i? Essentially replace the oil and gasket. Price guide would be helpful too.
We can do it for you. Price would depend on what transmission is fitted and the correct oil for that trans. You would need to do the filter as well and make sure the wiring harness loom fitting and change shaft seals are not leaking.
