keen
e30 light protectors
Ive had one broken the left one anyone got one for sale or the pair would be OK
I use the clear headlight film you cut to size from supercheap. Get the thickest one, cut to size, clean the light with meths or similar, warm it up in front of the light (turned on), then stick to the light using some clear silicone - a very thin amount and don't smear with your fingers. - use gloves if you have to.
Sticks on forever, you can't tell they're there and they work.
If you don't use silicone they start to peel off fairly quickly.
Brilliant thank you very much I'll try it
