Cressidom 0 Report post Posted March 24, 2009 Good day all, I'm just trying to confirm if the M50 2.0 non-vanos engines have a knock/ping sensor or anything that will do/process engine knocking for the ECU. Thank you all, Dom Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted March 24, 2009 Good day all, I'm just trying to confirm if the M50 2.0 non-vanos engines have a knock/ping sensor or anything that will do/process engine knocking for the ECU. Thank you all, Dom no ,only the vanos engines have them .they have 2 senors bolted to the inlet side of the block. http://bmwfans.info/original/E36/Lim/325i-...11/ill-11_1161/ Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 24, 2009 Sorry Brent. Thats not correct E34 M50 Non Vanos with Siemens DME does have 2 knock sensors Part # 12141730029 Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted March 24, 2009 Sorry Brent. Thats not correct E34 M50 Non Vanos with Siemens DME does have 2 knock sensors Part # 12141730029 i thought so , but when i looked on the part numbers wern't listed .checked both vanos and non vanos , vanos engine is listed , non vanos teh part number is missing . i was pretty sure i had seen them when pulling engines apart . . thanks Quote Share this post Link to post Share on other sites
