bmw_guy
How to get rid of error light?
Is there anyway to get rid of the brake pad lining error light i think it is? It keeps flashing.
Let me know.
In regards to the picture its the error to the right of the P error.
1. Replace the Brake Pads? If OEM ones will have the sensor assembly, if not they most likely won't have any.
or
2. If you have replaced the pads, just solder the two ends of the sensor wire together (LHS Front Strut) assuming your car has drums in the rear?
or
3. Take the bulb out of the cluster
Sorted.
Edited by Brams
You have to buy a new brake pad level sensor thing from bmw. About $30 i think.
These should be replaced when your pads are changed but most non-bmw places never do this.
Its just a wire that plugs in with a small ceramic bit on the end that breaks when the pads get to a certain level i think.
Yer they are not geuine BMW pads. I think i will just remove the bulb :P
Cheapest and easiest solution haha
O and empty your inbox
ha goooh dont do that brook, do it proply!
Doesn't solve the problem.
I guess im one of those that like everything working nice and correctly, peace of mind type of thing.
Ahh the dodgy bulb days. Wired my ABS light to my engine light in my GTZ once to pass WOF's. I had completely removed ABS, but hadn't certed it :ph34r:
You should change your nic to "Mr Dodgy" I think Peter :P
Do it the proper way brook!! Come round tomorow night for those springs and we will sort it out then.
Sweet Jase, yup ill come round tomorow at 6?
Guest Ari Gold
I like that you younger guys are helping each other out and aren't dodgy with your mods. *e-hug*
or
or
Sorted.
4. Black electrical tape over light in cluster? :ph34r:
^^ that was how we fixed engine over rev warning on an old isuzu truck :wacko:
Was able to get it to 100kph with that "fixed"
(Same truck also had the "brake light out" warning fixed that way too!)
Edited by blakamin
Thats what I did with the auto cluster in my manual e30 :ph34r:
