bravo 35 Report post Posted March 31, 2009 I have an oil leak form the filter housing. I swapped over housings when I swapped motors as I wanted to run an oil cooler. Now its leaking where the housing bolts to the block so must be the o-ring. Anyone know where to buy o-rings. Real OEM says its 65x3mm which sounds about right. May as well do the outer one too - 20x3mm Cheers. Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted March 31, 2009 Don't drink any beer when you do it! Its a easy job!!!11111! Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 31, 2009 I have an oil leak form the filter housing. I swapped over housings when I swapped motors as I wanted to run an oil cooler. Now its leaking where the housing bolts to the block so must be the o-ring. Anyone know where to buy o-rings. Real OEM says its 65x3mm which sounds about right. May as well do the outer one too - 20x3mm Cheers. Is there a Seal House in Whangas ?? I'd also do the thermostat "O" ring as well in the housing Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted March 31, 2009 Got them from Gavin. Not cheap though. Must find an o-ring shop up these ways. About $8ea o-ring. Quote Share this post Link to post Share on other sites
