jordyboy2 0 Report post Posted April 3, 2009 Any chance the E36 FRONT BREMBO 320mm BRAKE KIT Will fit a e46 If so Would they be better than the stock brakes on a 318 or 325 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted April 3, 2009 (edited) They should, because they come with the carriers too. You will need to check calliper / wheel clearances. However those rotors look like theyre past machining. You would need to measure them. You need .6mm to machine the surfaces. Ask the seller what thickness they are and what the Brembo min thickness is printed on the disc. You can work it out from that. If they are beyond machining you'll have to replace them. Edited April 3, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted April 4, 2009 Please name your threads better. "Will..." is not a thread title. Quote Share this post Link to post Share on other sites
jordyboy2 0 Report post Posted April 4, 2009 (edited) Cheers glenn My bad bravo Edited April 4, 2009 by jordy Quote Share this post Link to post Share on other sites
