Court M3
Auto feels sluggish
Guys got a problem. for some reason the auto tranny in my car feels slow and sluggish. When the accelarator pedal is pushed the car is revving but it hardly feels like it's going anywhere. Is this just the tranny going? Been this way since diff fluid was changed.
Haha, one would assume that since it's only happened since changing the diff oil that that'd be your problem. Perhaps you've put too much diff fluid in or the wrong type and that's causing your torque converter in the tranny to go nuts???
I would also check that your ATF colour is red, if it isn't then that's no good either and you should replace it with some nice shiney new red ATF.
Guys got a problem.
its an auto. get a manual, problem solved :D
