duke
e30 m3
hey there.
Im wanting to buy an e30 M3, but im not sure how to know whether one is just a 325 with the m bodykit or the real thing.. sorry bit of a dumb question, im not to knowledgable on the subject.. thanks.
Guest Spargo
Rear arches aren't welded onto the body, they're part of the unibody
Rear screen is at a higher andle, making it a genuine coupe, rather than a 2dr saloon
all arches are metal
Wider front and rear bumpers
Higher bootlid, matches height of the rear screen
Quicker ratio steering rack (3.5)
Oil pressure gauge where the swingometer usually is
Rear seat is molded differently, only seats 2 people
um, 4 cylinder motor :jap:
dogleg box if from Euro, stock if from the states
Different suspension mounting points and geometry in the front
5 lug suspension
These are the most basic differences, but the M3 only shares 2 panels with a normal E30, so keep that in mind. If you write one off, your life won't be worth living. Juzzie however, will sing your praises (another 10K onto the price tag eh J?)
Also the M-Tech bodykit looks NOTHING like the M3 "kit". Time for some research, grasshopper.
Yes, Sam is right, you may need to do a bit of research first.
It seems a bit strange wanting something you seem to know very little about.
However I can guarantee when you learn more about them, you will then REALLY want one. They are one of the greatest BMW's in my opinion. :D
Where do you plan on finding one? They are rather rare in New Zealand, and most people who own them would never ever give them up.
Also have you got somewhere between $35,000 - $60,000 to spend on an 18 year old car?
Cheers
unless you mean an M325i......these are just a 325 with a body kit......theres a few around, check trademe and stuff
2.3L or 2.5L DOHC 4 pot
eco guage replaced by Oil Temp not pressure. Im sure(not HIV 100%)
M3 will beat a 325 off the line but the 325 top end will reel it back in.
edit:(depends on the diff ratio in at the time, According to the BEN site)
Edited by bumpstop325
OT:
Maybe if the M3 is knackered and the 325 is worked!!!
The 2.5l 6cyl is more likely to have the bottom end torque to surge ahead off the line where as the revvy 2.3l (or 2.5l) 4cyl will have the topend power to pull away once it is up and going.
Best of luck finding your M3. Remember, take your time, and do your research. Otherwise, you will end up disappointed. Also, before purchase, engage a specialist BMW mechanic for half a day to look over the car - just to make sure that nothing problematic is waiting for you around the corner as they are VERY expensive to fix / parts are limited.
J
J
Brilliant brilliant advice.
Cheers
Not quite $10k, but approaching that.
