Boost Junky
Solid mounting rear subframe
The complete list as emailed to me by Will:
E30 M3 LCA bushes.
E36 M3 Evo LCA's.
E36 Struts
E30 Offset/adjustable topmounts and spring plates.
E30 springs.
I should have mentioned they were M3 Evo arms ha.
You need the top mounts as well because I believe the Evo LCAs also increase the track.
If you're putting coilovers in you're probably putting them in anyway.
As Cam said this should get you close to right.
