mattgoldsbro 0 Report post Posted April 24, 2009 When i bought car i knew it was in need of a new microfilter as blowing bugger all air through !! But now we are heading into winter have noticed that there seems to be no hot air either !! Would a new microfilter solve this or is it part of the heating system ? Have had a new thermostat fitted. Car is a 1996 E36 with the digital display for heater/ac controls. Any ideas ??? Quote Share this post Link to post Share on other sites
|ncary 0 Report post Posted April 24, 2009 I'd check your coolant levels a.s.a.p. Could be running very low. That, or an air bubble, or blocked valve somewhere. Hope it's one of the latter 2. Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted April 24, 2009 if your car is a singapore car its possible the heater has been blocked off.... Quote Share this post Link to post Share on other sites
mattgoldsbro 0 Report post Posted April 24, 2009 (edited) Car is ex Japan, Coolant level fine ... Not too sure where to start looking ,valves etc?? Edited April 24, 2009 by goldbro Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted April 25, 2009 When i bought car i knew it was in need of a new microfilter as blowing bugger all air through !! But now we are heading into winter have noticed that there seems to be no hot air either !! Would a new microfilter solve this or is it part of the heating system ? Have had a new thermostat fitted. Car is a 1996 E36 with the digital display for heater/ac controls. Any ideas ??? try replace the heater valves , or maybe the digital control panel , most common causes . Quote Share this post Link to post Share on other sites
mattgoldsbro 0 Report post Posted April 25, 2009 how can i tell if it is the valves ? ,the control panel seems fine . Any pictures of valves etc would be helpfull Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted April 26, 2009 how can i tell if it is the valves ? ,the control panel seems fine . Any pictures of valves etc would be helpfull you can pull them apart , you will see perrishing of the rubbers in side etc Quote Share this post Link to post Share on other sites
mattgoldsbro 0 Report post Posted May 2, 2009 you can pull them apart , you will see perrishing of the rubbers in side etc Have removed the valves and seems the rubber inside has perished, gave pistons etc a bit of clean. Was wondering if there is anyway you can gut these valves out and leave in open posistion ? Would that cause any probs ? dont really use air con or cooling just need heat in the winter.. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 2, 2009 Have removed the valves and seems the rubber inside has perished, gave pistons etc a bit of clean. Was wondering if there is anyway you can gut these valves out and leave in open posistion ? Would that cause any probs ? dont really use air con or cooling just need heat in the winter.. Just go new or 2nd hand Quote Share this post Link to post Share on other sites
driftfinatic 2 Report post Posted May 5, 2009 Im having similar problems. but mine has a mind of its own. it has problems changing from say feet to windscreen. and the fan has a mind of its own. it wont blow on full and then i turn it down and itll go crazy. im so confused. also iv have got no heat either. grrrrrr Quote Share this post Link to post Share on other sites
mattgoldsbro 0 Report post Posted May 16, 2009 Im having similar problems. but mine has a mind of its own. it has problems changing from say feet to windscreen. and the fan has a mind of its own. it wont blow on full and then i turn it down and itll go crazy. im so confused. also iv have got no heat either. grrrrrr Have replaced heater valves with 2nd hand ones all good now ! Maybe your heater control unit is stuffed ?? The are for sale on trademe reconditioned for $100. My heater still makes some random noises like there is a squirrel being starngled in the dash but atleast i have heat now!!!! Quote Share this post Link to post Share on other sites
