APT 198 Report post Posted April 30, 2009 I was driving on the motorway the other day and as soon as i reach to about 85 km + i feel the car starts to shake.. Has this happend to anyone before ? My first thought on it was just a wheel alignment, so i got my wheels balanced and aligned but still has a bit of a shock.Could it be bushings ? Any thoughts ? Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted April 30, 2009 Id say bushes, even things like wheel nuts on tight, shock mounts, tie rod ends etc etc I am no pro tho, just personal experience. Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted April 30, 2009 Check the driveline, mainly the centre hanger, and the rubber guibo? Quote Share this post Link to post Share on other sites
Kaz 64 Report post Posted April 30, 2009 Yeah I have the same problem and wanna know how to solve it. Quote Share this post Link to post Share on other sites
bmw_guy 0 Report post Posted April 30, 2009 I also have the same problem Quote Share this post Link to post Share on other sites
APT 198 Report post Posted April 30, 2009 Yeah I have the same problem and wanna know how to solve it. Thanks guys quick reply Anybody know of where to get some good quality bushings? - might give it a crack this weekend Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted April 30, 2009 (edited) ^^ its the chromes jk. + 1 Check the center hanger bearing + mount, mine was f**ked after I recently took the driveshaft out for the first time. My car has only done 185 thou k's so be worth to check Edited April 30, 2009 by Forrest Quote Share this post Link to post Share on other sites
APT 198 Report post Posted April 30, 2009 I also have the same problem I thought i was the only one Quote Share this post Link to post Share on other sites
Kaz 64 Report post Posted April 30, 2009 I have had it for a while and heard of a couple others with this too. Although mine tends to be at a bit higher speeds. I wouldn't have a clue why it does it though sorry. Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted April 30, 2009 Can be incorrect centre bore size on your rims as well if they're aftermarket and you're not running rings. Quote Share this post Link to post Share on other sites
Kaz 64 Report post Posted April 30, 2009 Can be incorrect centre bore size on your rims as well if they're aftermarket and you're not running rings.I think that could be whats wrong with mine. Any idea how much the rings are? Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted April 30, 2009 Talk to your local tyre shop, not too expensive I don't believe. Otherwise talk to Jono, "zenetti" on here. Quote Share this post Link to post Share on other sites
Kaz 64 Report post Posted April 30, 2009 Alright, thanks! I'll take it down to magwarehouse tomorrow and see if they can sort something out. Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted April 30, 2009 Other cause could be a bent rim, sometimes wheel balancing can fix this but not always. They can sometimes miss it too when they do the balance. Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted April 30, 2009 i can really suggest a wheel balance, had the same prob with the 325i, swapped a set of rims on i knew were balanced and the problem was fixed Quote Share this post Link to post Share on other sites
APT 198 Report post Posted April 30, 2009 i can really suggest a wheel balance, had the same prob with the 325i, swapped a set of rims on i knew were balanced and the problem was fixed Well i got my wheels balanced and aligned at HYPER last week so i dont think it could be that.. thanks tho Quote Share this post Link to post Share on other sites
zenetti 0 Report post Posted April 30, 2009 as SILVERFOX suggested it will almost definitely be locating rings. Make sure you have them sorted our first before you go checking bushes etc. Quote Share this post Link to post Share on other sites
