Driftit 2205 Report post Posted May 11, 2009 Am interested in any options my 540 may have for an LSD. Obviously not a fan of the horrid open diff. Is there any other diff units or internals I can use other than the M5 unit ($$$$$$$$$$$$$$$$$$$) or a custom unit? Apparently the E34 diff is not compatible. Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted May 11, 2009 http://www.performancegearing.com/live/ I believe the only options are Custom or M5. You've probably seen this info. Here is what you need for the complete M5 conversion: 1988 750i rear diff spindles (required from the M5 diff to the 540 axles) Existing 540 axles E39 M5 diff E39 M5 drive shaft Install is about 5-hours Quote Share this post Link to post Share on other sites
Driftit 2205 Report post Posted May 11, 2009 Wow that seriously sux. For a start the M5 diff is around $1200USD. Presume the drive shaft would be over $600USD. Then trying to find 1988 750 diff spindles, yeah right. Bugger. Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted May 11, 2009 Some very good info. http://forums.bimmerforums.com/forum/showt...ht=e39+lsd+swap Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted May 11, 2009 If (and its a big if) the internals are a standard BMW medium case ZF LSD you could swap in any medium case centre. ****IF**** thats the case. Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted May 11, 2009 Goddam I heart my E34 today Jeebus that's inconvenient. So it'd be safe to assume that the E39 540i6 came without LSD or has the option of the M5 one from factory? Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted May 11, 2009 i have a large case e32 750i lsd diff and a large case e34 540i diff . both 2.93 ratio . but might have other options on ratios if that helps with the bits you need. 021433600 Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted May 11, 2009 talk to Palmside about some Quaife yummieness Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted May 11, 2009 So are the 540i medium case or large case? Or neither? Hmmm - more research suggests possibly neither, in which case disregard my previous post. Quote Share this post Link to post Share on other sites
pjay 8 Report post Posted May 11, 2009 Lock it Quote Share this post Link to post Share on other sites
Driftit 2205 Report post Posted May 11, 2009 (edited) talk to Palmside about some Quaife yummieness Cheers that has helped a bit. I might look at the Quaife unit. As finding second hand E39 M5 parts in NZ..... Well. Looks like this is only going to happen if I really want to spend some coin. I miss Nissan's sometimes. Anything from anything will bolt to anything in a Nissan. Would have thought there would be an easy internal swap. Why did these cars not come with an LSD. Instead they just set the traction control to be overactive. lol. Cheapest I have found is $850USD on Ebay for an M5 unit. They can also do the driveshaft. Would end up around $2500NZD by the time I finish. Edited May 11, 2009 by driftit Quote Share this post Link to post Share on other sites
Guest Ari Gold Report post Posted May 11, 2009 A quaife ATB (torsen type) prices at: QUAIFE ATB Diff. Conversion Kit + Application : 530d,535i, 540i Installation cost : £337.90 Parts cost : £829.06 Quote Share this post Link to post Share on other sites
Driftit 2205 Report post Posted May 11, 2009 Excluding VAT? I think I will go for the quaife unit once I can put enough money aside. Suspension will come first though. Well a full service is first. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted May 12, 2009 Excluding VAT? I think I will go for the quaife unit once I can put enough money aside. Suspension will come first though. Well a full service is first.and this is why i sold my 540iT , you cant mod them easy like a e34 Quote Share this post Link to post Share on other sites
