Driftit
E39 LSD options
Am interested in any options my 540 may have for an LSD. Obviously not a fan of the horrid open diff.
Is there any other diff units or internals I can use other than the M5 unit ($$$$$$$$$$$$$$$$$$$) or a custom unit?
Apparently the E34 diff is not compatible.
http://www.performancegearing.com/live/
I believe the only options are Custom or M5.
You've probably seen this info.
Here is what you need for the complete M5 conversion:
1988 750i rear diff spindles (required from the M5 diff to the 540 axles)
Existing 540 axles
E39 M5 diff
E39 M5 drive shaft
Install is about 5-hours
Wow that seriously sux.
For a start the M5 diff is around $1200USD. Presume the drive shaft would be over $600USD. Then trying to find 1988 750 diff spindles, yeah right.
Bugger.
If (and its a big if) the internals are a standard BMW medium case ZF LSD you could swap in any medium case centre.
****IF**** thats the case.
Guest Simon*
Goddam I heart my E34 today
Jeebus that's inconvenient. So it'd be safe to assume that the E39 540i6 came without LSD or has the option of the M5 one from factory?
i have a large case e32 750i lsd diff and a large case e34 540i diff . both 2.93 ratio .
but might have other options on ratios
if that helps with the bits you need.
021433600
So are the 540i medium case or large case? Or neither?
Hmmm - more research suggests possibly neither, in which case disregard my previous post.
talk to Palmside about some Quaife yummieness
Cheers that has helped a bit.
I might look at the Quaife unit. As finding second hand E39 M5 parts in NZ..... Well.
Looks like this is only going to happen if I really want to spend some coin. I miss Nissan's sometimes. Anything from anything will bolt to anything in a Nissan. :mellow:
Would have thought there would be an easy internal swap. Why did these cars not come with an LSD. Instead they just set the traction control to be overactive. lol.
Cheapest I have found is $850USD on Ebay for an M5 unit. They can also do the driveshaft. Would end up around $2500NZD by the time I finish.
Edited by driftit
Guest Ari Gold
A quaife ATB (torsen type) prices at:
QUAIFE ATB Diff. Conversion Kit +
Application : 530d,535i, 540i
Installation cost : £337.90
Parts cost : £829.06
Excluding VAT? I think I will go for the quaife unit once I can put enough money aside. Suspension will come first though. Well a full service is first.
and this is why i sold my 540iT , you cant mod them easy like a e34
