Docile 64 Report post Posted May 27, 2009 my driver side door hinge switch for the window is acting up. anyone know how to remove it so i can check the sensor/switch and/or replace it? looks like i will need to get behind the back window panel to access it? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 27, 2009 my driver side door hinge switch for the window is acting up. anyone know how to remove it so i can check the sensor/switch and/or replace it? looks like i will need to get behind the back window panel to access it? Just take the striker of the "B" pillar with the 2 tamper screws and then you can check it Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted May 27, 2009 depends what year . early coupes have a switch inside door where door handle mech is , later e36 coupe have a switch built into the b piller latch Quote Share this post Link to post Share on other sites
Docile 64 Report post Posted May 28, 2009 the switch is like right behind the door latch on the car frame. was annoying a couple of nights ago.. it made the window go up and down continuously and kept triggering the alarm at 3 am !!! my car is a 95 coupe e36. so i just take the latch out and the switch wont fall inside in between the panels?? - id so hate to have to fish it out of there !! Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted May 28, 2009 the switch is like right behind the door latch on the car frame. was annoying a couple of nights ago.. it made the window go up and down continuously and kept triggering the alarm at 3 am !!! my car is a 95 coupe e36. so i just take the latch out and the switch wont fall inside in between the panels?? - id so hate to have to fish it out of there !! i thought being a 95 model it will have teh little switch in teh door jam part which wear down with use and need to be replaced or adjusted .have some good ones (take them from the left side have less wear ) $20 021433600 Quote Share this post Link to post Share on other sites
