va23boam 0 Report post Posted June 1, 2009 (edited) Hey all, Im wanting to have have some gauges mounted in my e30 wanting volt, oil pressure and maybe one more. maybe water temp. all gauges will be electrical and 2". i will also supply either a piller mount or dash mount bracket. main reason for installing is with it being such an old car i get paranoid that its going to run out of oil or the alternator will fail ect .. whats the going rate to install something like this. i can supply all the gauges (all brand new autometer) its my run about (740is are expensive to run!) 1986 318i i would probably prefer to have the work done in south Auckland as i work in east tamaki or if any members can do it even better! Edited June 1, 2009 by va23boam Quote Share this post Link to post Share on other sites
APT 198 Report post Posted June 1, 2009 (edited) Hey all, Im wanting to have have some gauges mounted in my e30 wanting volt, oil pressure and maybe one more. maybe water temp. all gauges will be electrical and 2". i will also supply either a piller mount or dash mount bracket. main reason for installing is with it being such an old car i get paranoid that its going to run out of oil or the alternator will fail ect .. whats the going rate to install something like this. i can supply all the gauges (all brand new autometer) its my run about (740is are expensive to run!) 1986 318i i would probibly prefer to have the work done in south Auckland as i work in easy tamaki or if any members can do it even better! Hey there, give it a go they are not too hard to install esp. the volt gauge. Otherwise if you are wanting someone in south auckland there is a member in here with a workshop in takanini Give Mike 323e30 a PM hes doing my conversion atm and a real easy guy to talk to. Good Luck, Im going to get this done soon too.. You cant trust the old e30 temp gauges lol even the fuel sometimes Edited June 1, 2009 by mybmw Quote Share this post Link to post Share on other sites
