mynbmr 225 Report post Posted June 7, 2009 I took my instrument cluster out to change some light bulbs but now my air bag indicator light flashes first then after a while it stays on permenant. Do i have to reset it on the computer or is there anything else i can try? Thankyou Dutchy Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 8, 2009 Did you have the steering wheel & air bag off ?? Quote Share this post Link to post Share on other sites
mynbmr 225 Report post Posted June 8, 2009 Did you have the steering wheel & air bag off ?? No i did not thanks Glenn Dutchy Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 8, 2009 (edited) Will need scanning for a fault code or just clearing fault codes....could be coincidental Edited June 8, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted June 8, 2009 Ha mine did the exact same thing, pulled the cluster out, put it back in and now the airbag lights flashing, must just be a ghost fault that comes on when the connectors are off. A simple clearing of the faults should do it. Quote Share this post Link to post Share on other sites
