wellyd
E30 Odometer not working.
....by that I mean several of the E30's on Trade Me have mentioned it, and guess what, just found out mine has stopped. Is there an easy fix? Is there a hard fix? Thanks in advance for your help!
one of the little drive cogs in the odo gear mech breaks .
easy enough to swap it out from a donar odo meter
it'l fix itself! mine did i bought mine and odometer and the rev counter didn't work.. i was waiting till the weekend to fix it but was too busy that weekend and it ended up being like 3 weeks.. but the day i went to fix it it started working and never had problem with it again :)
anyway i got a whole cluster for $50 with 126,000 on it. worked up untill engine came out of car last week. i live in Chch though. PM me if you're keen.
sometimes the pins on the plugs on the back of the speedo cluster get corroded. Maybe check that before you go spending too much. there easy to clean, just use crc co-contact cleaner.
