JaseNZ 53 Report post Posted June 13, 2009 I finally decided to go ahead and buy some rubber protection guards for behind my door handles. Total cost was $51 for all four but thats way cheaper than going through bmw which require you to buy the handle as well a piece. I got them from here >>Click Here<< about 10 days delivery and soon as i get them i will do a proper review and pics of the quality and replacment so if any body else is intrested they can decied if they would like to do the same. Quote Share this post Link to post Share on other sites
JaseNZ 53 Report post Posted June 25, 2009 Well they turned up today so time for out with the old and in with the new. This is the set that arrived This is what my current ones look like A comparision of the old and the new And the new ones installed. Overall i am pretty happy with the set. Best way was to drop them into some hot water before putting the on as they are not as easy as one would think. $50 for a set of four as opposed to having to pay $50 for the rubber and the cover from the dealer you can't go wrong. Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted June 25, 2009 Very good. Might be interested in doing this. Did you have a writeup to go off? Keen to know how to put them in, wouldn't have a clue how to. Quote Share this post Link to post Share on other sites
JaseNZ 53 Report post Posted June 25, 2009 Yup i came across this on how to get at them. >>Click here for info<< You will need to make-up a bit of a hook for pulling the slide back once you have replaced the rubbers. Once you look at the link you will know what i mean. Its very easy to do. The hardest part i found was trying to push the cover back into the door while tying to hook the slide at the same time. Helps to have somebody else there if possible to hold it in place for you. Took me about 30mins to do all 4 seals. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 25, 2009 On E36 coupes its harder... the whole window has to come out and be realigned and reinitialised Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted June 25, 2009 On E36 coupes its harder... the whole window has to come out and be realigned and reinitialisedtell me about it , a door swap for a e36 coupe .takes about 2-3hrs . every thing needs to be stripped out then put back in Quote Share this post Link to post Share on other sites
