danutt 4 Report post Posted June 23, 2009 ive asked around , spoken to many stupid people who know nothing and spoken to some that seem to know something but no one actually seems to know anything haha i have an e28 1985 with a 3.91 ratio diff and 4 speed auto box.....i have to use alot of the pedal just to stay going the same speed on a hill let alone accelerate up it so ive decided to change it closest to a 4.45 as i can yes people say rediculous things like itl buzz the cockpit but my mate has an e30 running a 4.45 diff on a 6 cylinder and its goes really well and doesnt rev high on the motorway cruising my car gets 75 in first 120 in second and who knows in third heard you can swap the internals???(it has 6 bolts on output flange so its medium case?...should be able to swap internals from a medium case e30 diff as long as its 6 cylinder??) can use e30 drive shafts? i cant really tell if its a mdeium case or large case diff as far as i can tell it measures a little longer and a little wider than the e30 diff with 6 bolts on the flanges i have already found a 4.27 from an e30 looks like a medium case with 6 bolts either side on the output flange so yea if there are some people here that know how to proceed it would be greatly appreciated!! Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted June 23, 2009 If they are both medium case diffs, you should be able to swap the rear covers and the drive shaft flanges (they just pop out) from your e28 diff to the e30 diff ... and you're done. You might need to change the plug for the speed sensor. Which city are you in - could be keen on the 3.91 at the right price. Quote Share this post Link to post Share on other sites
morerevsm3 7 Report post Posted June 23, 2009 if they both have 8 bolts holding rear cover on, they are medium case, and just follow instuctions above^ Quote Share this post Link to post Share on other sites
danutt 4 Report post Posted June 24, 2009 just had a look again now at the rear covers and the e30 diff has 6 bolts holding the rear cover on and mine has 8 bolts what case is the e30 diff?thought it would be medium case diff coming out of a e30 2l straight 6?? yea id let the 3.91 go for cheap if i can get a 4.27 or 4.45 on the e28 Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted June 24, 2009 most 320ia have small case . some 320i manuals and SA models have medium case . all 325i have medium case but much lower ratio numbers like 3.64 and 3.73 etc it will be harder to find 4.11 and 4.45 in a medium case Quote Share this post Link to post Share on other sites
danutt 4 Report post Posted June 24, 2009 most 320ia have small case . some 320i manuals and SA models have medium case . all 325i have medium case but much lower ratio numbers like 3.64 and 3.73 etc it will be harder to find 4.11 and 4.45 in a medium case well i can get my hands on a 4.27 and 4.45 small case diff possible to swap these internals?? anybody know for sure?? anybody done this before? thanx Quote Share this post Link to post Share on other sites
danutt 4 Report post Posted June 24, 2009 just found out can only swap medium to medium case so not keen to even get into trying my hand at swapping the internals so i got a price for a 4.45 thatl go straight in but what i want to know is if anyone here has a 4.45 medium case diff and for how much?? thanx Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 24, 2009 (edited) just found out can only swap medium to medium case so not keen to even get into trying my hand at swapping the internals so i got a price for a 4.45 thatl go straight in but what i want to know is if anyone here has a 4.45 medium case diff and for how much?? thanx With the 3.91:1 diff in the car the engine will be doing 3,200rpm @ 100kph in top gear with the tyre size your running. With a 4.45:1 diff it will be reving to 3,673rpm @ 100kph Is that what you want ?? Are you sure your performance issues are not engine or gearbox related ? Remember also your car is quite heavy and only a 2 litre Edited June 24, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted June 24, 2009 just convert it to a manual . i have all the parts (from a e28 525e) except the gearbox it self , but they come up pretty often. or do a 2.5 or 2.7 engine swap while you are at it Quote Share this post Link to post Share on other sites
danutt 4 Report post Posted June 28, 2009 With the 3.91:1 diff in the car the engine will be doing 3,200rpm @ 100kph in top gear with the tyre size your running. With a 4.45:1 diff it will be reving to 3,673rpm @ 100kph Is that what you want ?? Are you sure your performance issues are not engine or gearbox related ? Remember also your car is quite heavy and only a 2 litre dont think it will rev that high at 100kph my brother has a 320i with a 4.45:1 and its doing just under 3500 at 110kph thats more than fine with me yes the car is heavier but a higher ratio will make a drive up a hill less effort and thats what im after have managed to locate a 4.45 now just to get the cash together and il let you all know how it goes after:) cheers for all the help Quote Share this post Link to post Share on other sites
